Is "Targets" pull-down list in LabVIEW 2010 editable?
NI guys,
I have installed the TouchPanel module in LabVIEW 2010 but the corresponding "Touch Panel Project" does not show up in the "Targets" list of the "Getting Started" initial LV window. The Add/Remove dialog confirms the module is installed... Is this editable?
Thanks in advance
(2,870 Views)
Hi golubovski,
Good question.  To access the Touch Panel Project Wizard, you can open the new dialog box and select Touch Panel Project from under the Project >> Project from Wizard folder.  You can also find this information in the help file, Creating a Project Using the Touch Panel Project Wizard
In regards to editing the "Targets" list, I will investigate that.  I assume you are looking for an easier way to launch the Touch Panel Project Wizard?
Elizabeth K.
National Instruments | Applications Engineer | www.ni.com/support
(2,840 Views)
Elizabeth,
Yes, I'd appreciate that shortcut to creating new TouchPanel project.
Thank you
(2,829 Views)
Accepted by golubovski
I believe that the Touch Panel Project should be added to the Targets drop down when you install the Touch Panel Module.  Since it is not, I believe that it is a bug.  Thank you for noticing that, and I will file a corrective action request to get that changed for future editions of LabVIEW.
Elizabeth K.
(2,808 Views)
