Is the Aardvark OEM I2C Host Adapter supported with Labview?
Hi All,
I am now looking forward to use Aardvark OEM I2C Host Adapter (http://www.totalphase.com/products/aardvark-oem-i2c/)
in LabView2013.
Question:
  1. Is this device supported with LabView?
  2. How can I use this device?
Best Thanks,
Jessie
(4,746 Views)
Did you even do a search of this site or the vendor's? The vendor has a LabVIEW driver and it is discussed in several threads.
(4,731 Views)
Hi Dennis_Knutson,
Yes I did. But they only mentioned Aardvark I2C/SPI Host Adapter not Aardvark OEM I2C Host Adapter. ?
Best Thanks,
jessie
(4,711 Views)
And you don't know the difference? Not even a question for this forum.
p.s. What is the point of the multiple colors m
(4,703 Views)
Yes
We have plan to buy and use Aardvark OEM I2C Host Adapter and use it with LabView2013.
I am searching if this device already has LabView VI's for I2C communication.
I am not sure If we can use the VI's for Aardvark I2C/SPI Host Adapter to Aardvark OEM I2C Host Adapter.
Before we decide  to buy Aardvark OEM I2C Host Adapter we just want to make sure that we can use it.
Best Thanks.
Jessie
(4,693 Views)
So either look at www.ni.com/idnet to see if drivers for that exact model exist or call Aardvark and ask them what the differences are between the devices to determine if the API they've built will communicate with both devices.
Asking here won't give you a better answer than Aardvark will.
(4,685 Views)
As I already said, the VIs are available from the vendor. Pointless to post here about the difference with the oem version.
(4,678 Views)
