Simple PWM Generation
The PWM was running good when I haven't add in the temperature reading block diagram. After adding that in, the PWM signal becomes very slow. Is it because the device itself is sampling 1 point at a time for both reading and writing which then slows the system down?
http://forums.ni.com/ni/attachments/ni/170/880111/1/1.jpg
http://forums.ni.com/ni/attachments/ni/170/880111/2/2.jpg
(4,479 Views)
Why not put them in separate loops?
(4,456 Views)
Probably.
Try wiring the Stop control into the Stop? terminal of the express VI.
(4,446 Views)
I tried wiring stop control and it didn't work. Putting them into seperate loops is working but I'm expected to use just 1 loop
(4,427 Views)
What DAQ device. Single point read or write is slow. If you have a hardware timed device, you should be using that.
(4,422 Views)
I'm using myDAQ
(4,406 Views)
With software timed digital, it's a pretty poor choice for pwm. You might also want to try LabVIEW functions instead of the formula node.
(4,394 Views)
