Is the Labview executable program can create new shotcutshortcut
In my Labview application the user is selecting one of the programs on the disk to be StartUp application (after the computer booting, selected program should run).
To meet this requirement the Labview application should create selected program shortcut and locate it in StartUp.
(3,449 Views)
Take a look G Toolbox at:
http://gtoolbox.yeah.net
George
George Zou
(3,449 Views)
I did not find in G Toolbox something that can help to solve my problem.
(3,449 Views)
Hi Alex,
I have attached a small VI and DLL which you can use to create a shortcut in Windows. You have to provide some paths and a comment to get a standard shortcut which works fine for Win32 Applications. I hope the name of the controls are clear enough.
Waldemar
Waldemar
Using 7.1.1, 8.5.1, 8.6.1, 2009 on XP and RT
Don't forget to give Kudos to good answers and/or questions
(3,449 Views)
Hi Waldemar
Thank you for your help.
(3,449 Views)
