Convert LStrHandle to C++ Char
I use CIN and I have a problem.
I have a problem to use SPrintf with my C++ project. In my declaration, I wrote extern "C".
What is the solution to convert a Labview String (LStrHandle) to a C++ string (char[]).
Thanks for help.
Sam.
(8,627 Views)
> string (char[]).
In extcode.h there is the definition
typedef struct {
int32 cnt; /* number of bytes that follow */
uChar str[1]; /* cnt bytes */
} LStr, *LStrPtr, **LStrHandle;
The string is a counted string since NULL termination doesn't work well
with binary strings. The char[] and uChar[] are compatible, and so you
can either copy cnt characters of the string to a C++ object from the
str field, or if you really know what you are doing, you can use the
pointer as a C++ string after adding a NULL to it. Its easiest to add
the NULL on the diagram before calling the CIN, but there are functions
to do it from the CIN.
Greg McKaskle
(8,627 Views)
Thank for your answer.
But I'm a beginning to C++ programmer and I don't understand fully the answer.
Do you have a code to replace :
" LStrHandle data;
char cmde[512]="";
SPrintf(cmde, "%H",data);"
SAM.
(8,627 Views)
>answer.
Take a more close look at the struct in the previous post (extcode.h)
and follow and interpret the actual behaviour of a smart compiler
after typing in the character string "(*data)->"
>" LStrHandle data;
> char cmde[512]="";
>Thanks
>SAM.
char cmde[512]="";
int i;
char* cmdd = (char*) malloc((*data)->cnt*sizeof(uChar)+1);
for (i=0; i<(*data)->cnt; ++i)
cmdd[i] = (*data)->str[i];
cmdd[(*data)->cnt]=0;
sprintf(cmde, "%H",cmdd);
free(cmdd);
Jac.
(8,627 Views)
Thanks Jac,
the idea are good but cmdd is char and (*data)->str[] is uChar. We have a problem to convert and the string cmde is not correct.
(8,627 Views)
In extcode.h there are two macros for LStrHandle :
LHStrLen give the number of char and LHStrBuf give the char * ( str[0] )
LStrHandle a
LHStrLen(a) = (*a)->cnt
LHStrBuf(a) = (*a)->str[0]
Then you can use a printf with LHStrBuf
Bye , Eric
(8,627 Views)
