How to change the default "digits of precision"
I am using labview 6 now. The default digits of precision is 2. I wonder if there is a way to change the default digits of precision, so that I don't need to change it every time when I use an indicator.
(3,655 Views)
Not really, there's an undocumented ini setting for setting the default precision of a control, but not the number of decimal places...
Of course you can create your own control with the number of decimal places set to what you want. Every time you place that control you will get the number of places it was set to.
For example, attached is a numeric control with 9 decimal places. Every time you use it you'll get 9 digits of precision.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(3,655 Views)
The undocumented ini setting Mike mentioned (I believe) is
defPrecision
See
http://labview.brianrenken.com/INI/undoc.shtm
for more info.
Ben
(3,655 Views)
