how do i display my labview front panel on a web-page and update it say eyery 5 seconds, I think i need Lookout?
My front panel display updates every 20secs. I want to be able to view the Labview front panel on a web-page which updates itself continuously. Will Lookout do this?
(2,994 Views)
LabVIEW will do this with it's built in web server. Full control of a LabVIEW front panel is possilbe with version 6.1. Older versions have the ability to publish a panel with no control. What version do you have? Lookout is a completely different software package for HMI/SCADA applications and has no relationship to LabVIEW except that they're sold by the same company.
(2,994 Views)
I have Labview version 6.0. I only need to publish my front panel. i don't need to control it. Will i be able to update the web page regularly?
(2,994 Views)
I am doing something similar at present, and am using the get image invoke node and write jpeg functions. These images are stored on the server, then you have the option to put meta refresh tags on your html page
(2,994 Views)
Yes you will!
LV 6 web server enables you to publish a front panel on a web page, both static and animated.
Take a look at Chapter 17 of LV user manual: Publishing VIS on the Web.
Alberto
(2,994 Views)
