How to control I2C bus with a DAQ
I have timing problems with NI-DAQ harware and sometimes i can control the bus. If the PC that is running the Labview 6.0 is doing som other work the timing does go out of sync on the digital I/O NI-DAQ harware. Has someone made a programm to control I2C bus with standard digital I/O card or DAQ from made by NI.
(3,102 Views)
No I have not done I2C with DAQ.
In a Windows environment, you will not be able to enusre that you will be able to react deterministically to bus events.
I wrote a wrapper to use a PCI interface for I2C a couple of years ago. It worked good.
Since then I have read that others have gotten good results using a serial to I2C adapter.
I would suggest that approach. Otherwise, the approach you are taking may become an "exercise in futility".
Ben
(3,102 Views)
