Home
Community
Discussion Forums
Most Active Software Boards
Topic
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
can't delete files from installer
Allen Weekley
Member
03-04-2003
05:05 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
Existing LabVIEW 6.1 .bld file - I can delete files from "Source" tab but not from "Installer -> Files" list. I need to get rid of a dll I am no longer using, but it won't remove from the installer list. The Remove button is grayed out.
0
Kudos
Message
1
of 3
(4,286 Views)
Reply
Re: can't delete files from installer
Allen Weekley
Member
Author
03-04-2003
06:05 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Problem solved! There was still a call to the dll in my source code. When I removed it the dll no longer appeared in the installer.
1
Kudo
Message
2
of 3
(4,286 Views)
Reply
Ben
Knight of NI
03-05-2003
07:37 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Good, now if the inverse was always true....
Ben
Retired Senior Automation Systems Architect with
Data Science Automation
LabVIEW Champion
Knight of NI
and
Prepper
LinkedIn Profile
YouTube Channel
0
Kudos
Message
3
of 3
(4,286 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
