Is the old HPAL now the Multicore Analysis and Sparse Matrix Toolkit
I'm trying to find a download for the HPAL that used be offered by NI Labs.  It's supposed to be a addon to LabView now from NI and I'm looking for the download.
The appears to two possible addons that ths became; either the Adavnced Processing tookit that costs about $1500 or the Multicore Analysis and Sparse Matrix Toolkit which I think is free. Does anyone know what the HPAL became?
(4,014 Views)
Accepted by walleye
Yes, you are correct...
the High Performance Analysis Library was packaged to be called LabVIEW Multicore Analysis and Sparce Matrix.
And it is still free to use.
I hope this helps.
Barp - Control, Simulation, RTT and HIL - National Instruments
(3,960 Views)
Barp,
Thanks for for the answer.  I'm glad it's the free one.
Later
Walleye
(3,953 Views)
You say it is free to use, but it is downloaded only as a temporary trial toolkit.
On LV2014, it says Evaluation License (40 days).
How do I convert that to "Licensed"? I tried activating with my LV2014 S/N, but that doesn't seem to work.
(3,770 Views)
Hi waynep,
Did you download it using the link above and choose to download using VI Package Manager? I was able to download it and start using it without any sort of activation.
Is it asking you to activate? If so, where is having you activate it? I didn't see any chance or option to activate it when I downloaded and installed it with the VI Package Manager.
Brandon Grey
Certified LabVIEW Architect
(3,747 Views)
When I searched for it (prior to reading this thread), I found the file:
NIMASMT2014.exe
I also see the .vip file:
national_instruments_lib_multicore_analysis_and_sparse_matrix_toolkit-15.0.0.13.vip
But, I installed the first one, not the .vip. I could use it right away, but it is on a ~ 40 day evaluation license.
If I install from the .vip file, does that not have a limited evaluation period?
Right now it shows up on the license manager and asked me to enter a S/N. I tried my current S/N (LV 2014 professional), but it did not accept it. Thus, I was left on an eval license.
Thanks for your help.
(3,741 Views)
If you install the toolkit in VI Package Manager using the "Download through VIPM (recommended)" link on this page, you shouldn't have an evaluation period.
Brandon Grey
(3,737 Views)
