Jared,
Thank you for responding to my posted message. Rendezvous is a new concept to me, maybe
it's the solution to my problem. I have been trying to read the on line manual and
example VIs from National Instruments website. I still have a hard time to understand
the concept.
One of the example I saw is using rendezvous to run some sub VIs. But in my case, I have
only one VI that is a while loop. Inside the while loop, there are a few tasks running
simultaneously. I don't know whether it will serve my purpose.
Guangde Wang
Jared O'Mara wrote:
> Guangde,
> Referring to your 2nd method, use rendezvous (under advanced>>synchronize
> on function palette) to synchronize two processes. There are good examples
> that come with labview. basically, you cre
ate a rendezvous, giving it a
> size. Using the wait on rendezvous vi, a function will not continue until
> all rendezvous have reached that point. Using this method, you can synchronize
> your 2 while loops.
> Jared
> Guangde Wang wrote:
> >I tried two ways to control the tempo of my program.>>One is to use the
> While Loop's counter and a wait. The drawback of this>method is the cycle
> length is dependent on the measuring load. So if the>program runs for days,
> it will be significent off the real time.>>The other way is to use the difference
> of the Tick Count. It provides>accurate timing but the problem is the sychronization
> of the clock cycle>and the While Loop cycle. I can try to put a little bit
> wait but still>can not sychronize them very well. So after a while, there
> will be two>measures get together.>>I don't know whether there are some better
> ways to control the program>or whether we have some ways to improve either
> or both of the above
two>methods to make them work better. Please let me
> know if you have any>suggestion.>>Thank you in advance,>>Guangde Wang>
