Is there a better way to generate custom timed digital Signals
OK you can look at what I helped someone do in the example that I am attching and you can also look at this discussion to see how it progressed.
http://forums.ni.com/t5/LabVIEW/Digital-Output-Sequence-variable-timing-NI-9472/m-p/1605436#M583011
Tim
GHSP
Message 11 of 15
(769 Views)
Yes
Message 12 of 15
(767 Views)
I don't understand the code. Can you provide a simple code that just trigger one line to high/low at random intervals?
Message 13 of 15
(759 Views)
Accepted by panoramarts
This is an example that does exactly that.  It's software timed, so it's not perfect.  It cycles through an array using a for loop with auto indexing.  On each iteration, it changes the state of the digital output (as determined by the "boolean state" array), and sets a delay time (the "Time (ms)" array).  The "Actual Delay Times" calculates the actual loop iteration time.  This could be easily adapted to be used for multiple lines of output.
Jon S
Applications Engineer
Message 14 of 15
(724 Views)
Thank you!!!
Message 15 of 15
(710 Views)
