Is there a function to record time stamp with user input?
Hello all,
I am new to Labview. I have a question regard a particular function that I hope Labview can do and hope someone can help me out.
Our group started to use Labview about two years ago. We use it to record a counter every second. We challenge our sample with chemicals and record the changes in real time. We have been recording the event (chemical flow start and end) time manually. But I think that Labview should be able to record it if we input by clicking a button to indicate when to record a time stamp. Is there a way to do that? I hope I explained our situation and purposes clearly.
Any help is much appreciated.
By the way, our LabView is 2010 version.
(3,183 Views)
If you are reacting to a button press, you want to use an event structure.
(3,179 Views)
Use an event structure that handles the value changed event of your start button.
In this structure you might place a "Get Date/Time In Seconds" functions. This will give you the time stamp at the time you start your test.
(3,152 Views)
