Is there a keyboard shortcut for "pause" and "resume"?
I searched carefully but could not find such a shortcut. Is there a keyboard shortcut for "pause" and "resume" on the LabVIEW window?
(7,128 Views)
If its for debugging purpose, use Breakpoints..
https://www.ni.com/docs/en-US/bundle/labview/page/managing-breakpoints.html
(7,126 Views)
It is not for debugging purposes.
(7,124 Views)
Hi Finkler,
so then you should explain what you're talking about!
Which "pause" and "resume" do you mean?
(7,118 Views)
I run a VI by pressing the "Run" button (or Ctrl-R). After some time (nevermind why) I need to pause the VI. I typically do that by pressing the "Pause" button. Since I'm running this remotely from another computer, I would like to be able to press this button using a keyboard shortcut. Afterwards, I press the "Pause" button again to resume the VI.
(7,115 Views)
Accepted by Finkler
Hi Finkler,
so you are using a debugging feature! And no, there seems to be no shortcut key assigned.
When you need a VI with the ability to "pause" you should learn about state machines. They are a common scheme to incorporate such "states" as "running" or "paused" in a VI (or program in general)...
(7,111 Views)
