01-23-2007 01:37 AM
BTW, if this is correct, one way to find out might be putting the exe inside the LabVIEW folder. Presumably if it is in exactly the same place as LabVIEW.exe, it should have the same paths, but that's just a guess.
Another option might be not to load the vi.lib VIs dynamically.
01-23-2007 08:01 AM
01-23-2007 08:19 AM
01-23-2007 08:23 AM - edited 01-23-2007 08:23 AM
Message Edited by batesbc on 01-23-2007 08:28 AM
01-23-2007 08:27 AM
OK, I just did a quick test and it seems that this is indeed the case - dynamically calling a VI that points to a vi.lib VI returns an error 1003, but moving the executable to the LabVIEW directory solves this.
So the quick solution to your problem would be to put the exe in the LV directory, but if you already have LV installed, you might as well use it run the application.
The other option is to create distributions of your VIs which will include the vi.lib VIs, either as LLBs or as folder hierarchy. The problem with this is that it is more complicated and that you need to try avoiding creating duplicate hierarchies with the same VIs or (worse) different versions of the same VIs.
01-23-2007 08:35 AM
01-23-2007 11:30 AM - edited 01-23-2007 11:30 AM
@batesbc wrote:
Good to know that others have done projects larger than ours, I was a little worried when I got a short stunned silence at an NIWeek '05 session about LabVIEW 8.0, they were talking about the (then-new) Project Explorer.
Does the 255-character limit on individual paths apply to the length of the viSearchPath variable? (When LabVIEW reads the .INI file, is it only retrieving the first 255 chars of that string?)
LabVIEW paths have only a 255 character limit per path hierarchy level. This is because LabVIEW uses a Pascal String for each level. Another limit a LabVIEW path has is a 32767 path element levels. That means a path can consist at most of 32767 hierarchy levels since the numbers of levels is stored in an int16. As you can see this is very unlikely to be ever a problem. Under Windows the Winapi limit of 260 characters for a complete path (unless you use a special trick wich only works for some APIs that are also available as Unicode variant) is much more likely to cause problems and getting around that limit is a nightmare of its own.
And no! LabVIEW does not read 255 character for the viSearchPath but any and all there are up to 2^31 chars, the theoretical limit for LabVIEW string handles.
Rolf Kalbermatter
Message Edited by rolfk on 01-23-2007 06:39 PM
01-23-2007 03:38 PM
01-23-2007 03:50 PM
Another option for fixing this is copying the entire vi.lib folder into your application folder and this should presumably solve your problems, but I'm not sure if this is legal and you might find out you have problems when calling things like DAQmx.
In general, I still believe the best solution would be either to create a distribution or to place some of the low level VIs into your build and take the memory hit.
