Is there a possibility to retreve Data from the OPC Server with the XML Interface
Is there a possibility to connect a OPC/DA server with the help of the XML interface with Labview?
I need to retrieve Data from a OPC Server running on Linux, so i got no Dcom System an I need to use XML. The server is running and with OPC client-tools i can access de different data. So now I want to visualize all Data
that come from that server on Labview.
1. Is it possible to realize that?
2. Is a library or a demo vi available ?
Regards
Densel
(2,476 Views)
Hi Densel,
Sure, you can use XML within LabVIEW, the question is which syntax do you use?
Are you able to send the XML statements via TCP/IP?
Regards, Christian
(2,457 Views)
