Is there a simple way to display a number in the most logical unit?
Hi, often I'm taking a measument in a VI and displaying it in real time in my front panel. Often, the range of the measurement changes drastically in a short timespan. What I'd like is for it to display it in the simplest units. So for example, if the measurement is in volts, and it's currently 2E-8, I'd like it to say 20 nV instead. Now obviously if I wanted it to always be in nanovolts, I could just multiply the display by 10^9, but sometimes it will quickly go from nV to mV or something, and I don't want it then displaying 3E5 or something.
So what I'd really like it to do is have it automatically adjust to use the "closest" unit. I know I could do this using some logic statements or maybe a Ring, but that's kind of clunky. Is there a more efficient way to do this? thank you.
(3,244 Views)
Do you know the display format properties?
Try SI- notation Format 🙂
Rigth-Click on the indicator, choose Display Format..
Greetings from Germany
Henrik
LV since v3.1
(3,227 Views)
Accepted by optoelectro
Set the display format to SI notation.
(3,226 Views)
One addition:  Add a log, fixed scale bargraph for a quick optical view!   Since m,µ,n,p mix up quickly 😄
Henrik
LV since v3.1
(3,220 Views)
Awesome, exactly what I want!
(3,203 Views)
