Is there a way to add scroll bar to a front panel cluster control?
I have a cluster control on my front panel.  The cluster contains many controls that I do not have enough room to display all at once. When an array contains more elements than is displayed, you can turn on vertical or horizontal scroll bars.  This not seem to be the case for the cluster control.  I do not see a scroll bar property for the cluster control.  Is there a way to display one that I am missing?  Thanks!
Message 1 of 16
(12,520 Views)
Not statically. See these ideas:
http://forums.ni.com/t5/LabVIEW-Idea-Exchange/Allow-clusters-to-have-quot-pages-quot/idi-p/1481862
http://forums.ni.com/t5/LabVIEW-Idea-Exchange/Scroll-Bar-Property-for-Clusters/idi-p/921174
It is possible to do this at run-time by placing the cluster inside another cluster with a scroll bar and then writing code which will control the position property of the nested scrollbar, but I understand that's not what you want.
___________________
Try to take over the world!
Message 2 of 16
(12,491 Views)
Accepted by NI-hilator
As far as I am aware you cannot display scrollbars on clusters.
The only method I can think of around this would be to display the cluster fully expanded on a subpanel as a plugin and have attached an example of how to do this.
Hope that helps,
Dave
David Clark
CLA | CTA
Genesee Technologies Ltd
Hampshire, England
Message 3 of 16
(12,490 Views)
Thanks for the replies! I think David's example will work great! Kudos.
Message 4 of 16
(12,476 Views)
There are deprecated properties that will do it, but their behavior is a bit flakey.
Message 5 of 16
(12,468 Views)
@pcardinale, what kind of "flakey" behavior have you seen with it. Seems to work as expected on my end. This property node would be a big help in cleaning up some front panels I use.
Message 6 of 16
(11,337 Views)
Sometimes the scrollbars disappear when you adjust them.
Message 7 of 16
(11,296 Views)
@pcardinale, thanks for your exemple,  the problem, i do not find the scrollbar in the Property Node of cluster !! Way please !! I lost a lot of time
Message 8 of 16
(9,596 Views)
Its a depreciated property.  Better to use a sub-panel (and really, check is that "Mother Cluster" should even be shown.
Message 9 of 16
(9,585 Views)
This is a pretty old question concerning adding a scroll bar to a cluster control on the front panel.  I assume most people have figured out a way around this by now.  I found myself needing to scroll through a cluster of controls recently and found this thread.
The way I was able to get around this was to open the "Layout" tab on the front panel controls menu.  Then select "Vert Splitter Bar".  This allows you to break up the front panel in multiple scrolling sections.  A scrolling horizontal bar as can be added as well with the "Hor Splitter Bar".  The items can be left in the cluster or used as independent controls & indicators.
Message 10 of 16
(4,971 Views)
