Is there a way to disable a single control within a cluster?
I have a cluster with three controls in it, two of which are mode dependent.
I wish to disable one of those two for mode A and the other for mode B.
All I have found is a way to disable the entire cluster.
Can I disable just one control?
Thanks in advance
(3,905 Views)
If you create a property node for the cluster, then right click the property node, go to "link to", mouse over the cluster which has the check mark by it, and it should show a list of the items in the cluster.  You can select one of those items and know the property node is linked to that item.
Nate
(3,900 Views)
Thanks!
Works just like I needed.
May the software gods smile on you as quickly when you have a question.
(3,893 Views)
glad to help!
(3,887 Views)
Not only that, but this solved another problem that I had.
I have been using local variables for some config initialization and things like that.
I have some clusters with a numeric control and a button.  The button is "latch when pressed"
LabView will not allow local variables with that mechanical action (even though it is only used once at initialization).
Now that I know how to get a node for a control in a cluster (actually a control in a cluster in a cluster) I can use that for initialization.
Thanks again.
(3,879 Views)
Watch out...if you try to use a property node to change the "Value" property of a latch boolean, you'll get error 1193.  It's the same reason you can't have local variables of latch booleans.  Because of this, one simple solution I usually do is to change the boolean action to switch, but perform initialization on the value, then a final value set during cleanup...so I'm making a switch boolean act like a latch boolean.
Good luck,
-D
(3,867 Views)
Thank you for the heads up, but I am not trying to change the value of the boolean.
I have a cluster with a switch and a control setting.  When the switch is pressed, the control setting is transmitted to a peripheral.  I wanted to initialize the control setting using one of the CONFIG VIs and couldn't set the value.
I am using the property node to set the value of the control, not the switch.
(3,863 Views)
