Home
Community
Discussion Forums
Most Active Software Boards
Topic
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
Is there a way to generate a XY 4 quadrant plot?
FredFred
Member
02-07-2006
09:38 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
How can I generate a 4 quadrant XY plot in LabVIEW.
I see that there is a Polar Plot, which does ideally what i want to do with the 4 quadrant XY plot.
Thanks!
0
Kudos
Message
1
of 2
(2,733 Views)
Reply
Re: Is there a way to generate a XY 4 quadrant plot?
unclebump
Active Participant
02-07-2006
10:31 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
You should be able to turn off Autoscale on the axes for the standard XY graph. Then use property nodes to set the max and min values for each axis to put zero in the center..
1
Kudo
Message
2
of 2
(2,722 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
