Is there a way to generate a XY 4 quadrant plot?
How can I generate a 4 quadrant XY plot in LabVIEW.
I see that there is a Polar Plot, which does ideally what i want to do with the 4 quadrant XY plot.
Thanks!
(2,734 Views)
You should be able to turn off Autoscale on the axes for the standard XY graph. Then use property nodes to set the max and min values for each axis to put zero in the center..
(2,723 Views)
