Is there a way to interface argox cp-3140L printer with labview
I need to generate 2D datamatrix barcode from labview using Argox CP-3140L printer, is there a way to achieve this???
(3,325 Views)
First instal LabVIEW and Vision Development module and generate the 2D datamatrix barcode. Refer http://www.ni.com/example/30539/en/ this link on how to generate code. once it is complete go for priniting Argox CP-3140L printer provides multiple communication interfaces including parallel, RS-232, and USB ports,  so use any one but it is good to use USB interface as it is easy to communicate.
hope this information helps..
kudos are welcome 🙂
Certified LabVIEW Developer
Best LabVIEW Programmer @NIDAYS 2015
(3,315 Views)
