c-RIO 9004
How to power my CRIO 9004 ? will I require a seperate power module or can I connect it from the DC supply available in my lab?
Thank you
(3,611 Views)
Did you even try to look for the datasheet/manual for the 9004?
(blog)
(3,600 Views)
If you did go to the page that was linked to (more or less) you'd find this information on the overview page.  It is also detailed in some of the resources documented linked.
http://sine.ni.com/nips/cds/view/p/lang/en/nid/14161
Featuring low-power consumption, the cRIO-9004 accepts 9 VDC to 35 VDC power supply inputs on power-up and 6 VDC to 35 VDC power supply inputs during operation.
(3,587 Views)
Thank you
(3,557 Views)
