Shared variable Deployment
Hi guys,
Im trying out shared variable.
Everytime I run the VI, there is a deployment progression.
How do I hide this pop up window everytime I run the VI?
(4,834 Views)
Anyone have any idea?
(4,772 Views)
As far as I know, you can't. The latest version of the shared variable libraries must be deployed to the shared variable engine each time you run it, unless it's running in an executable.
(blog)
(4,760 Views)
Right click on "My Computer" in the project and check "Disable Autodeploy Variables"
(4,749 Views)
Hi, this is the pop up.
I dont see ''disable autodeploy variables''.
I only see it when building exe.
Any other alternative?
(4,728 Views)
No, not in that dialog.
In your project.  In the build specs for creating an .exe there is a section called Shared Variable Deployment that has a check box that says "Deploy shared variable libraries at applicaiton execution".
(4,720 Views)
