07-09-2005 08:21 AM
Uh yup, you're right everything was getting written--except the data. Oh well... It was getting late last night.
In any case, I have played a bit more and attached is a version of the VI that does save the data and cleans some other stuff up as well. For example, note how I write the data to the subvis. Although I have heard that this method is not quite as efficient as using indexed control references, I prefer it because it is more robust in that it isn't dependent upon a hidden parameter (tab order) to stay connected to the right controls.
Note also the data passing. To maintain the polymorphism of your interceeding code layers, I converted the application-specific data types to a variant data type. In this way Remember Values and Make Current Default can handle the data without worrying about what the real data type is. (Actually something you might want to consider is whether the you still need both of these VIs...) The only other impact to passing variants is that the template VI has to make the conversion back to a LV datatype so I had to add a Run VI before saving the new defaults. Reading the data shouldn't change because the "Read" case bypasses all the code so all you'll see is the output's default value.
Using variants as a polymorphic data type is a very helpful technique, take some time to be sure you understand it. You will want to use it again sometime...
I have also cleaned up the error passing so all errors will eventually find their way back up to the top level VI and be reported. In addition, I added a case structure to prevent the creation of an extra spurious data VI. The problem is that the database assess node doesn't assert EOF until you have read past the end of file. You might want to look up how to access the log files using the standard file IO VIs. That approach might be more flexible is you have several log files of each type to convert.
If you have any other questons on what I have done just ask...
Mike...
07-09-2005 03:31 PM
07-09-2005 04:21 PM
Brock;
I am sending this same information in a private email, but am repeating it for the sake of anyone else who might be following this thread...
I hear you in terms of ease for your users to create their own templates. However, with a couple minor modifications to the code, it still shouldn't be too hard to describe what they need to do. Starting with the data template. On the diagram there is a hidden control of the proper data type connected to the top terminal of the function for converting the varient back into "their" data type. Replace this with a local variable created off the output indicator. This way when a user is wanting to create a new version, they just have one indicator to change to create a new template type and then save the VI with a new name (with a *.vit extension!).
In terms of the polymorphic VI add-ins, modify the code I sent you last to move the name of the template to be opened into a front panel control that has the proper name stored as the default. All your users would then have to do to create their own version of the polymorphic VI is to change the name in the control to match the name of the template VI they already created, save new front panel defaults and replace the input data control with "their" data type. Everything else should just work... (Oh yes, they'll of course need to add their new write VI to the polymorphic VI.)
Mike...
07-09-2005 05:03 PM
07-09-2005 05:25 PM
Go for it Ben.
Mike...
07-11-2005 06:59 AM
Brock;
One more thing. I was thinking about your comments last night and it occurred to me that you could actually write a small utility program that would create your users' VIs for them--and it wouldn't be horribly hard. What do you think?
Mike...
07-11-2005 05:29 PM
07-11-2005 06:13 PM
Brock;
You're right, you can't progamatically edit clusters. However, if you play your cards right you don't have to. All you have to do is take advantage of a feature in LV that many people think is a bug. Consider for a moment that you have a VI (named template.vit) that uses a typedef control named (for the sake of argument) template.ctl. If you have any control open in LV with that same name when you open the VI template it will link to the one you have loaded into memory--not the "correct" one from the disk. Essentaily you will have replaced one control with another one. Once the new link is established in memory, save the control and VI with a different names (in that order) and badda-boom badda-bing you have a new VI that is linked to a different control than you originally created it with.
See where I'm going with this? ![]()
To prove it to your self that this works, you can do it manually. Then all you have to do is write a small program to use VI server calls to do the same thing...
Mike...
07-12-2005 02:21 AM
07-20-2005 12:33 PM
