Is there a way to reinitialize the background color of all the cells in a table?
I am programmatically updating the values in a table and highlighting the failing points for a visual reference. I want to be able to run this vi several times consecutively and start from scratch each time.
(3,009 Views)
The idea demonstrate in Setting Table Cell Colors Programmatically
example may be of help.
(3,009 Views)
Try setting your active cell to "-2,-2" and then set your color.
As I understand the indexes work like this;
Index value location
0,1,2,... data cells
-1 column/row headers
-2 entire table
Ben
(3,009 Views)
That was great. Exactly what I was looking for. Thanks a lot Ben. If you don't mind, may I contact you directly for any other future questions?
(3,009 Views)
Hi Alpine,
Thanks for your kind words.
re: Contacting me directly.
I am one of the consultants with one of NI's Select Integrators (Data Science Automation see dsautomation.com). As such, my first responcibilities are to my my existing customer base. Currently I am on the middle of two very intense development efforts. One of which is a rather interesting third party devlopment application and the other is is on the front lines of fighting the war on terrorism.
So...
I do not have a lot of spare time.
Suggestions;
1) Keep posting to this list like you just did. Most of what I know about LV I picked up from this site plus "Info-LabVIEW" (Thank you Greg and Rolf!).
2) Mention my name in the first line of the question, if I have tim
e I will try to respond.
3) If you really want to talk to ME we offer a "dial a Ben" service where you issue a PO and we charge based on the actual time spent answering the question.
I hope you do not take offense in this answer, but I "gotta feed the family" :<)).
Ben
(3,009 Views)
I understand completely. Thanks again for the help.
(3,009 Views)
