Is there a way to use the F keys?
Well, I've found VIs that display the current key pressed, but none of the F keys seem to register. Does Labview even recognize these keys??
Message 1 of 10
(4,172 Views)
The key down? event seems to handle the F keys just fine.
So does the key down event, but LV will still handle the default behavior, like open the help. But you do get an event.
The problem with the "other VIs" is probably that they only look at the char value of the event. You need to consider the VKey.
Message 2 of 10
(4,164 Views)
Here is an example:
Look at the scan code
Tim
GHSP
Message 3 of 10
(4,158 Views)
Or scan code...
Message 4 of 10
(4,155 Views)
Yes it does,
Place an event structure, add an event for Key Down
"Char" it will give you the ASCII code for the key pressed
"VKey" will give you Esc, Enter, Shift, Ctrl,..., etc. F1, F2,... F12, etc.
Saludos.
Message 5 of 10
(4,153 Views)
Well, the KeyDown field in the LabVIEW Event structure (present for at least as long as I've been using LabVIEW) provides a lot of data (some of which you might need to look up/research):
Message 6 of 10
(4,080 Views)
wiebe@CARYA wrote:
Or scan code...
That works until someone changes their layout to Dvorak or some custom keyboard. 🙂 (A colleague build 4-row keyboards instead of the common 6 rows where e.g. 1-0 is on the Q-P keys with a modifier.
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 7 of 10
(4,060 Views)
Keyboards such as this. 🙂
Qestit Systems
Message 8 of 10
(4,042 Views)
@Yamaeda wrote:
wiebe@CARYA wrote:
Or scan code...
/Y
Well, it depends on what you want. If you want to catch a press of a specific physical key (regardless how it's configured or interpreted in the OS), the scan code should be used. Not sure if I've seen a practical use case, but I'm sure they are there.
Message 9 of 10
(4,038 Views)
The 1st thing that comes to mind is default setup for a game. Imagine the WASD on a Dvorak ... 🙂 If you map through scancode you'd get the right positions as default.
/Y
Qestit Systems
Message 10 of 10
(4,032 Views)
