ā03-29-2010 02:24 PM
Is there an easy way to convert a "1d array of strings" to a "2d array of unsigned bytes" (U8-8 bit integer).
Solved! Go to Solution.
ā03-29-2010 02:49 PM
Hi chuck72352,
this should work.
Mike
ā03-29-2010 02:50 PM
ā03-29-2010 03:01 PM
Attached is the VI that I believe you showed me. Output exists in only the first column. Did I misread your vi?
Thank you.
ā03-29-2010 03:06 PM
I attached the wrong file should be as attached.
ā03-29-2010 03:11 PM
Attached is the VI as I believe you showed me. Only the first column is being populated.
ā03-29-2010 03:19 PM
HI chuck72352,
as i wrote in the image. First change view to "code display" and then enter "\t" as seperator.
Mike
ā03-29-2010 03:29 PM
ā03-29-2010 03:31 PM
