Is there an elegant way to compute a running average?
I am using the attached Sub vi to collect data from 3 channels. I would like to calculate a running average (3 - 10 data points) in an attempt to "smooth out" the data for each channel.
In the Labview training manual there is a way to use a shift register and averaging the values, but is there a better way to perform this calcultion in Labview 7.1?
I am using this sub vi in 2 places. Once in an idle loop and once to acquire data (attached screen shot) when a motor is moving.
Bill
(3,340 Views)
I happen to think a shift register is pretty elegant but if you have the full version of LabVIEW, you can try the Mean PtByPt function (which happesn to make use of a shifter register, btw).
(3,329 Views)
Is the Mean Point by Point included in one of the "Toolkit" software components?
(3,298 Views)
It's included with the full version of LabVIEW. If you don't have the base version, it will be on the Analyze>Point by Point>Probability and Statistics PtByPt palette.
(3,289 Views)
I thought I had the full blown version.  I don't have the discs with me right now but I think there are about 10 discs for the "NI developer suite".  At the time we were getting quarterly updates from NI.   Also, I have the ability to create executables if that's any indication.
As I remember, I loaded the following discs: Labview 7.1, Professional development system, 2 device driver discs. I suspect I need to load additional software.
How do I confirm if I have the base package?
(3,268 Views)
The professional version includes all of the functions that are part of the full so you should have the VIs. The fucntion palette has a search button on it. Click on that and do a search for Mean. If you are using the Express palette view, you have to select the All Functions button to see all of the palettes.
(3,265 Views)
Thanks, I found it!
(3,254 Views)
