Is there an official 7.1 bug fix list?
Does anyone know if there is a list of bugs fixed since 7.0. Also, was there a 7.01 release after 7.0?
Some of the bugs I've run into which I'm wondering if they were fixed are:
1) xy graph axis appears over graph instead of next to graph when programatically hiding and then reshowing.
2) xy graph axis when using multiple y axis get out of order when hiding and reshowing programatically.
3) Scaling is broken when using tab control. When using tab control and relying on auto scaling, tab becomes progressivly out of place and seems to grow until until tabs disappear.
4) Can't seem to get access to plot location in xy graph. I can get plot size, but not location which is really a pain if you need to position custom indicators along various plots when you can't programatically determine the location.
5) Auto scrolling graph with cursor only auto scrolls first axis in multiple y axis graph. Actually, I'd like to turn auto scrolling in the y-range off but leave horizontal x auto scrolling on. I think there's an ini setting to change the setting but it only works for both x and y. Is there a complete list of attributes that can be set in the ini file?
Other questions:
When auto scaling a front panel, is there a way to have front panel objects scale relative to an edge rather than the center? I saw that you can lock an object so that it isn't resized when you resize the panel, but it this doesn't work so well if what you're doing is using buttons in an array sized exactly to the height of the legend where these buttons are used to filter out certain plots. If I size the panel, the buttons grow and they become too tall and no longer match the height of the legend. If I lock them, then they don't change size, but then they no longer stay right up against the legend. In this case if I size the panel smaller, they start to overlap the legend. If I size larger, a gap is created.
Does anyone know if anyone has written any layout managers that could be used to do resizing and bypass LabVIEW's resize policy since it doesn't allow sticky locations and all the usual stuff we've come to expect from UI layout managers in the last 7 years(now it's sonding like a rant, but rest assured, I still think LV is the greatest 😉
(2,718 Views)
sorka;
You can check the LabVIEW Support page.
There is a troubleshooting section called LabVIEW Installation/Getting Started Resources. It also includes a LabVIEW 7.x Frequently Asked Questions that has a link that reads Issues Fixed in LabVIEW 7.1. However, not much information is provided there.
Other places where you can post your findings is at the LAVA Forum (check the Bug list forum) and the Info-LabVIEW mailing list. These are not official places, but usually they li
sten 😉
Enrique
www.vartortech.com
(2,718 Views)
