where do you get ai0 channel from for 3 hr course
I am doing the 3 hr beginners course I am in the 2b data acquistion section, I created the data assistant chose analog input then voltage, now I am in the next section, it tells you to select ai0 channel but i have no channels to choose from, can anyone give me a little help here. Thanks
(2,493 Views)
Sounds like you don't actually have a DAQ card installed in your PC. The DAQ assistant can't list any channels if there are none available. Unfortunatly, the exercises were written assuming you have a DAQ card.
Ed
Ed Dickens - Certified LabVIEW Architect
Lockheed Martin Space
Using the Abort button to stop your VI is like using a tree to stop your car. It works, but there may be consequences.
(2,493 Views)
thanks much
(2,493 Views)
