Is there any crush between LabView and other program ?
my system is win98 with LV 6.1. After installing this software (ACDSee 5), my program got error -10800, trigger timeout (my program is developped DSA.vi example) everytime i ran the program, it never happens before. Then after i uninstall the software, my program work just like before, no problemo.
Can Labview crush with other program ? How ?
(3,060 Views)
I don't think it's actually LabVIEW that's causing this problem but a hardware driver issue. Error -10800 is an NI-DAQ error. If you installed ACDSee (I like that name) it appears that they supply drivers also, so you're probably getting some problems with these two drivers being installed. Make sure that any other LabVIEW programs still run or if they generate this same error. If they do, then it's certainly the driver. Otherwise, it's a particular operation that's interfering with the ACDSee software.
J.R. Allen
(3,060 Views)
