all my program have an error of -10806
When i run the program (dsa.vi example and it's developped vi), the led of trigger timeout always on, this never happened before although i variate the scan rate and frame size. (LabView 6.1 in Win98, DAQpad 1200). This problem happened after uninstall the LV 6.1 and installing LV 5.1 then uninstall it then back install the LV 6.1 with install the network.
(2,472 Views)
This error could be occurring for two possible reasons.
1. No trigger value was found during the timeout period. You will have to double check your connections to ensure that you are properly configuring and sending the trigger.
2. There could be an issue with your NI-DAQ driver. When you installed LabVIEW 5.1 it may have installed an older version of the NI-DAQ driver and over written the newer version that comes with LabVIEW 6.1. I would double check which version of NI-DAQ is currently installed on your system. You can go to Windows Add/Remove Programs or launch MAX and look in the Software folder for the current version. I would recommend uninstalling the driver and reinstalling the newer version. You can download NI-DAQ 6.9.3 from our web site
at http://www.ni.com/downloads/
Justin Britten
(2,472 Views)
