Is there any support from labview for ADAM5000 modules
Is there anyone using ADAM5000 modules.In my application I want to communicate with ADAM module through serial port.Any example codes available in LAbview
(2,364 Views)
I couldn't find any instrument drivers for this particular device on our website (www.ni.com/idnet).
You need to get the documentation for the device, to determine things like the serial port settings and specially the command set used by the instrument.
You can then use the VISA VIs to send and receive data to the instrument.
DiegoF
National Instruments.
(2,364 Views)
