Is there any way to jump into a certain i (iteration round) in a For-loop if a certain rule is met?
The question is in the topic.
Help is appreciated.
(2,672 Views)
Accepted by Aleksi-
Nope.
Spoiler
You cannot influence the iteration count. It just counts up, starting from zero.
You may add an offset to "i" to "fake" a certain count value…
(2,658 Views)
...or use a while loop and maintain a loop count yourself using an incrementing shift register.
You can have a case structure in your loop that modifies this count under the required conditions.
(2,625 Views)
