Is there anyone that succeffully installed Labview for linux 2016 on Ubuntu 16.04?
Hello all,
I know about the supported OS. Is there anyone that succeffully installed Labview for linux 2016 on Ubuntu 16.04?
I executed the ./INSTALL as root:
>sudo su
>./INSTALL
I'm getting the following error:
./INSTALL: line 270: /media/username/2016LV-LinuxPro/bin/rpmq: No such file or directory
Is there a way to get more detail about what caused the error? I know the rpmq file exists and it is an executable.....
Michel
Message 1 of 17
(9,508 Views)
Accepted by Michel_Gauvin
I'm not linux specialist but from what I know Ubuntu is a Debian derivative and uses .deb packages while RPM is used on Red Hat (and other NI supported distributions).
You can try to convert one format to another, but I am not sure how well that would go.
Message 2 of 17
(9,480 Views)
I know, this is what I'm currently trying.  Will let you know.
Michel
Message 3 of 17
(9,468 Views)
Hey, it worked! I have LabVIEW installed (basic functionalities):
1. Converted the following two rpm with "sudo alien *.rpm" (* = name of the file)
- labview-2016-core_16.0.0-1.x86_64.rpm TO labview-2016-core_16.0.0-2_amd64.deb
labview-2016-exe_16.0.0-1.x86_64.rpm TO labview-2016-exe_16.0.0-2_amd64.deb
2. Installed using "sudo dpkg -i *.deb"
3. Launched labview executable from:
> cd /usr/local/natinst/LabVIEW-2016-64
>./labview
I will keep installing and update this thread with new information.
Michel
Message 4 of 17
(9,462 Views)
Hi Michel,
Where did you find the .rpm package? I can't find it on the NI website at all.
Cheers
Message 5 of 17
(8,970 Views)
It's not available on the website.
You need to buy it, there is no evaluation version.
Message 6 of 17
(8,959 Views)
I tried to convert these NI Labview for Linux installation RPM files to debian files and I keep getting an error from alien saying failed at line 489 which indicates that the RPM file isn't the correct format?
Any help thanks.
Message 7 of 17
(8,658 Views)
Can you upload the .deb version here
Message 8 of 17
(7,524 Views)
No not possible, see stockson answer above.
Message 9 of 17
(7,515 Views)
i tried doing this but still it wont work
is there any alternative that you could suggest please?
Message 10 of 17
(7,310 Views)
