Is there is current limit on the NI USB module 9263 Analog Voltage Out (+/-10V)?
There. 😇  Now I suppose you want an op-amp circuit???  🙄
LabVIEW Pro Dev & Measurement Studio Pro (VS Pro) 2019
Message 11 of 16
(379 Views)
Hi NIquist,
Thank you for these circuit diagrams. I am using NI9263 output analog DC (3V, 1mA) to drive a vibrator which needs 3VDC and 85mA. The terminal resistance of the vibrator is 30 Ohm. I can power the Transistor (2N222xx with a beta of 85) with an external power source (3V 600 mA)  What resistances would I need to comply with the circuit diagram, please?
Oxsanj
Message 12 of 16
(375 Views)
That's what I was going to suggest. A simple voltage follower can do the job.
Message 13 of 16
(369 Views)
Why resistors ? 😄
OK, a OP has no voltage drop but ...
Greetings from Germany
Henrik
LV since v3.1
Message 14 of 16
(335 Views)
@oxsanj1 wrote:
Hi NIquist,
Oxsanj
If you just want ON/OFF just use one transistor E to GND (of PS and DA), C to load to 3V , B with 1k to AO
Henrik
LV since v3.1
Message 15 of 16
(331 Views)
Thank you Henrik.
Message 16 of 16
(316 Views)
