Is there "bit operator" in LV?
IN VC or VB, there is the "bit operator", how about in LV?
If not, are there methods to do the same thing?
(3,107 Views)
What exactly do you mean with "bit-operator"?
Using LV8.0
Don't be afraid to rate a good answer... 😉
(3,103 Views)
Hi, becktho. In a binary file, every byte is composed of 8 bits, for example:10110110. I want to do the following operation
1*1+0*2+1*3+1*4+0*5+1*6+1*7+0*8. I don't know how to do thisSmiley Sad
(3,101 Views)
You could use the shift operator (palette > Numeric > Data Manipulation) or you could also use the logical functions (AND, OR, XOR, ...) with numbers.
Using LV8.0
(3,090 Views)
All of LV's logical operators will operate on numeric values.
Just wire you numbers to the input of the appropriate gate (And, or, X-Or,...) and the returned value will be the bit-wise result.
Ben
(3,089 Views)
You DO realise that 1^8 is equivalent to 1^4 which is equivalent to 1, don't you.  So 011101101 will result in 5, which is basically the sum of all the 1s in the byte.  Is this what you want?  Do you mean 1x2^0 + 0x2^1 + 1x2^3 + 1x2^4 and so on.....?
You don't mean simply casting the 8 bits to an U8 number, do you?
Do you have the 8 bits as 8 bits, or as 8 numbers, each set to either 1 or 0.  What data format do your numbers have?
If they're U8, you can use the function "Boolean array to number" to be found on the Boolean palette.
If they're bits, well you're basically already done.
Hope this helps
Shane
Using LV 6.1 and 8.2.1 on W2k (SP4) and WXP (SP2)
(3,090 Views)
Thanks, your guys. Problem solved. I use "number to boolean array" and " boolean to (0,1)"
(3,078 Views)
