Greetings, Julio:
There is also a pretty good example in the help file under Examples/Communications/ActiveX Examples, called, oddly enough, write table to Excel. Be sure you have EXCEL properly installed. You might have to change the default directory so Labview can find it
🙂Good luck!
eric
Eric P. Nichols
P.O. Box 56235
North Pole, AK 99705
