Is there some who ca give me an exemple or instructions how can i transfer data from labview to active x ecxel?
Thank you in advance.
(2,625 Views)
Hi Julro
Please check this:
http://zone.ni.com/devzone/devzone.nsf/webcategories/C3E56C69D399361E86256AB7006A9149?opendocument&node=DZ53003_US
Hope this helps
Luca
Luca
(2,625 Views)
Greetings, Julio:
There is also a pretty good example in the help file under Examples/Communications/ActiveX Examples, called, oddly enough, write table to Excel. Be sure you have EXCEL properly installed. You might have to change the default directory so Labview can find it 🙂
Good luck!
eric
Eric P. Nichols
P.O. Box 56235
North Pole, AK 99705
(2,624 Views)
