Moving around wires can be done nicely if you just understand how LabVIEW decides what parts of the wires to move...play around with them; if you hold down control while selecting wires you can select multiple wires at the same time..that way they will move nicely together...In some cases it's necessary to select both the horisontal and the vertical part of one and the same wire for it to move around the way you want...
A good tip when tidying up G code is that you can create empty space wherever you need it by holding down Ctrl while drawing the space you need where you need it with the arrow tool...then LV will move the surrounding code so that the empty space is created.
There is no in-built zoom function as far as I'm aware, but you can probably use general zoo
m utilities...Normally wires are never that packet; either you can easily select them...or they are on top of eachother...in the latter case try selecting the wire where it starts or ends, or temporarily delete a section of one of the wires to move the other one...
