Is this VI the right procedure to multiple boolean button?
Hello everyone. I made this VI's to use multiple boolean buttons for my scale (a "Open/Close" button and a "reset to zero" button). I want to make all commands from my device as boolean (ON/OFF) switches or buttons. Im asking for this procedure using while loop. Is this the right procedure. My VI is uploaded.
In my previous post, a user helped me and said, that i can use a Producer/Consumer state machine in this situation, but that program seems a bit advanced and difficult to me, because i'm inexperienced with Labview.
Thanks in advance
Oesen
Best regards
Oesen
Message 1 of 12
(3,997 Views)
What you want is an event structure inside of a while loop.
Message 2 of 12
(3,979 Views)
I used the program with that even structure, but i can't open or close the scale. Here is a screenshot :
Best regards
Oesen
Message 3 of 12
(3,945 Views)
Are you sure your termination characters are correct?
When you run a VI in highlight mode, the carriage return/line feed characters won't show up on the wires.  Yet in your screenshot, your data on the wire shows a \r\n.  That makes me think you actually have 4 characters in that string control of backslash, r, backslash, n.  That is not the same as a carriage return and linefeed.
Make sure your string controls are in \code mode before you enter \r\n into them.
Message 4 of 12
(3,942 Views)
Thanks for the help!.. I needed to change to code display. The only problem is the zero zoint button now. ON/OFF button works, but the zero point button doesn't give any respond.
Best regards
Oesen
Message 5 of 12
(3,910 Views)
What is the command supposed to be?  I didn't have any reference of the commands.
The way the VI is currently written, you need to toggle the Read switch in order to read the data from the instrument.  I should have made that a button.
Message 6 of 12
(3,893 Views)
Yes.. But the command for Zero point is "T\r\n". It doesn't give any respond:
Best regards
Oesen
Message 7 of 12
(3,880 Views)
Accepted by Oesen
Hah, I pointed to the wrong control.  I setup the event to look at the string instead of the button.  That's one of the dangers of having multiple controls/indicators having the same label.  The fixed VI is attached.
Also, you don't need to use the Run Continuosly button.  Just run the VI normally and use the stop button to stop the VI.
Message 8 of 12
(3,876 Views)
Your image does not show the event actually running. It also looks like you have clicked the run continuous button. NEVER use that except in special debug situations.
Message 9 of 12
(3,874 Views)
That's what he meant by "not responding".  Took me awhile to figure that out too.  I corrected the VI to have the event point to the correct control.
Message 10 of 12
(3,870 Views)
