Is two compactRIO ethernet communication possible?
I would like to know if is two compactRIO ethernet communication  possible without PC point.
(2,889 Views)
You can use TCP VIs in both the cRIO controllers and communicate with each other. I'm not sure about shared variables, but think that should also be possible.
Kallis
BR
(2,884 Views)
To achieve that you can use Shared Variables.
I will give you two links where you can find detailed information's and guidelines on how to distribute Real Time application with Shared Variables. Please review this documents and let me know if you have further question.
http://zone.ni.com/devzone/cda/tut/p/id/4673
Regards.
Omar. NIF
(2,856 Views)
