error 0xBFF6001F with a Kappa camera
I'm using a Kappa CF 8/4 camera with a PCI-1409 card.
I'm trying to snap an image with MAX, but it gives me the error 0xBFF6001F-Cannot detect recognizable video source.
I use the file CCIR(1409).icd (that's the video format as written in the datasheet) for the camera parameters.
The card works ( the self-test is ok) as the camera (tested with a picolo card).
Max gives me the right parameters concerning the number of bits and the dimension of the sensor pixels*pixels that appear down the window for the image.
I have LabVIEW 7.1, NI-IMAQ 3.1.3, MAX 4.1.0.3001.
Bye
(2,678 Views)
Hi man,
Did you right click on device and interface >> NI IMAQ >> img0  to configure the camera mode.
Can you try to increase the timeout in the Acquisition parameters.
Which version of NI IMAQ do you have?
Kamal
NIF
(2,659 Views)
