Is typedef?
Good afternoon
It is possible to know whether a reference belongs to typedef? if it is possible, you can get the path of the file that is linked?
Thank you very much
(3,616 Views)
It is a scripting node, but the TypedefPath is available for a Control
(3,604 Views)
Accepted by topic author dgd.gomez
In addition to the "TypeDef?" and "TypedefPath" scripting properties there is also a VI in the vi.lib:
vi.lib\Utility\VariantDataType\ContainsTypedef.vi
This is intended to be used on a complex data structure and will tell you if it contains a type def.
(3,576 Views)
Thank you very much for the reply. But I find what he says, you can add an VI example?
I found another forum: http://forums.ni.com/t5/LabVIEW/Know-programmatically-if-a-control-is-a-typedef/td-p/1909897, but finds jcarmody options.
My version of LabVIEW is 12.0.f2
Thank you very much.
(3,539 Views)
Hi, I keep trying to get the path but I can not. I found a link: http://lavag.org/topic/17702-strict-typedef-in-xnodes/ but I find the options palette XNode, in Propety Node. I am not able to find those options. No if someone can help me. Load the .vi example.
I'm new and I do not know where all things are, sorry.
(3,510 Views)
Do you have scripting enabled?  Go to your Tools >> Options, then the VI Server section and check the box "Show VI Scripting Functions"
Now your property nodes and invoke nodes will have a bunch of new methods.  Attached is a VI that uses those methods.
(3,470 Views)
