Issue adding timestamps to array
I'm attempting to augment a VI available from ATI to read a 6 axis sensor, and am having issues adding timestamps to each row of data. I can currently add timestamps, but they appear in a row below the force and torque data. I would like them to appear in the 1st column, and the data to be added to the subsequent columns (see below):
what I have:
What I would like:
I have included the VI (not sure if all the sub VI's are needed), and they part I'm augmenting is to the right in the block diagram. Last time I worked with labVIEW was 2 years ago, and I am a bit over my head. I apologize for the inputs to some of the array tools, I have been searching the forums piecing together previous solutions and help so I don't understand everything I have done here.
Additionally, if anyone can help me understand the "index into array" function, specifically in regards to "index 0...n-1" I would be very grateful. I feel like that is the key here, as it states that I can insert arrays into specific columns by wiring 3 to a specific index input, but I have no idea what they are referring to.
Thank you very much for the time and patience.
(6,244 Views)
Accepted by CBlevins
The problem is your are creating a1-D array of of time/date, have a 2-D array of values converted to as 2-D string array.  Then concatenate the 1-D array to the bottom of the 2-D array.
Also, it is rather pointless to insert a string of date/time into an empty 1-D array.  It just leaves you a 1 element 1-D array.
There is also an easier way to format the current time into as String.
 augment_atidaqftmx_BD
(6,237 Views)
Hello RavensFan,
Thank you very much for your prompt reply and help, I appreciate it. I changed the program per your recommendation and it worked as desired (I did flip the time and data inputs so that the time appears before the data).
(6,193 Views)
