Issue in Inserting and recognizing Hungarian(Hungary) language
Hello LabVIEW Users,
I am working on the Hungarian language based application and having trouble in two characters which are not recognized by LabVIEW as well as SQL Server2008.
Characters are ő and ű.
For more information, l have attached document here which shows that how LabVIEW and database recognize it.
Thanks ...
Message 1 of 10
(3,995 Views)
I suspect this is a "Unicode in LabVIEW" issue.  If you do a Web search on this topic, you can see the current state of this issue.
Message 2 of 10
(3,969 Views)
I am able to show characters in LabVIEW but not able to show(log) it into SQL server database.
Please see the attached image for more information.
Message 4 of 10
(3,946 Views)
But manually I can write those characters in database ,but can't write it through LabVIEW
Message 5 of 10
(3,945 Views)
Have you tried to change ist to utf8 before writing it to the DB? If reading it from the DB you have to change it back. For conversion there is a hidden LV function. Have a closer look here:
https://forums.ni.com/t5/LabVIEW/undocumented-function-quot-text-to-utf-8-quot/m-p/1034616/highlight...
Message 6 of 10
(3,936 Views)
This is a cool function if you want to write special characters like Ő as an utf-8 string to a text-file
but does piZviZ's SQL 2008 database accept utf-8, or rather UTF-16 encoded strings?
Message 7 of 10
(3,921 Views)
Can you upload same VI? I am not able to use snippet.
Message 8 of 10
(3,905 Views)
Download is in the link I've sent.
A more detailed description can be found here:
https://forums.ni.com/t5/Reference-Design-Content/LabVIEW-Unicode-Programming-Tools/ta-p/3493021
Message 9 of 10
(3,899 Views)
the LabVIEW Unicode Programming Tools
are a different resource (in regards to undocumented function "text to utf-8").
You could use those Unicode Tools to write an utf-16 string to file via LabView.
also, its a good resource to learn about unicode-specific tidbits (that may bite you) like utf16-LE and BOM
Message 10 of 10
(3,884 Views)
