Issue in bluetooth device connection using bluetooth protocol
I tried to connect the bluetooth device(Headphones/speaker) using LabVIEW bluetooth protocol but, it is not working as expected. I am able to hear the connected/disconnected audio from bluetooth devices but if I try to play any audio it is not playing through bluetooth devices. Even in PC settings it is not showing as connected. But if the bluetooth device is already paired to the PC, then if I try to run the same code I am able to hear the audio. Can anyone help in sorting this out?
(1,483 Views)
Hi rafik.m
Could you please provide more information to be clearly understandable.
Which type of Headphones are you using?
Did you try to detect it from NI MAX (with/ without USB connection)?
Are you sure that you have compatible drivers for your LabVIEW and PC?
Regards)
(1,398 Views)
