Issue in connecting sub VI programs through the main program
Thanks for immidiate reply!!!!
Can you please refer me any example through which I could understand the program. I am totally new to labview.
Message 51 of 92
(1,449 Views)
Hi ymanglik,
go to Instrument Driver Network: www.ni.com/idnet
Look up the driver for your K2410.
Install it.
Look at the included (example) VIs…
I'm pretty sure this has been told to you before!
Message 52 of 92
(1,446 Views)
I can't see how you can be totally new to LabVIEW, being as you have been using it for several months now.  The only way you could still be totally new to it is if you never followed up on any of the suggestions over the past few months. RTM and read through the LabVIEW tutorials.  Learn how to do your job so we don't have to do it for you.  (Although if you want to pay me for it, I could use the extra cash.)
Bill
CLD
(Mid-Level minion.)
Message 53 of 92
(1,434 Views)
Hello
I made this program of keithley 2410(attached) but it is showing error. please check and tell how to remove this error.
Message 54 of 92
(1,415 Views)
Hello
I see a blank for a resource name.  Is that how it is when you try to run it?
Bill
CLD
(Mid-Level minion.)
Message 55 of 92
(1,410 Views)
According to my previous post you should attempt to send the commands in a loop to see if any particular cause problem, and you must ofcourse open and close the VISA resource.
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 56 of 92
(1,391 Views)
Thanks for your suggestion!!!
I implemented this & program is running but still I am facing two problems. The program is working virtually but not interfacing with the device"Keithley 2410" and giving empty read buffer. I have checked in Devices and interfaces under Measurement & Instrumentation for VISA resource name. It is showing " ASRL1:INSTR " so I have doubt about this & want to know how to add GPIB VISA resourc under devics and interfaces.
Please tell me in detail.
Message 57 of 92
(1,364 Views)
I am sending you that file.
Message 58 of 92
(1,363 Views)
Hii dear all,
I am getting this error when I interface the program with the device "keithley 2410". Please tell me how to fix this error.
Message 59 of 92
(1,347 Views)
Hi ymanglik,
at first you should try to determine the property node/attribute by debugging which is throwing this error message…
Message 60 of 92
(1,341 Views)
