Issue in connecting sub VI programs through the main program
@Dennis_Knutson wrote:
Keithley calls it a SourceMeter. It is a variable supply with a built-in meter.
Sorry for the confusion and thanks for the clarification.  OMG the product name confused me.
Bill
CLD
(Mid-Level minion.)
Message 81 of 92
(1,265 Views)
Hello Yamaeda,
Can you please tell me how to change the polarity. Which command should i use to change the polarity??
Regards
ymanglik
Message 82 of 92
(1,243 Views)
Hello everyone,
can anyone tell me about these command:
:SOUR:SWE:DIRE UP;
:SOUR:SWE:DIRE DOW;
Are these commands not valid for keithley 2410 device because it is not accepting these commands and giving error: 113 undefined header. can anyone tell me  what would be right commands for sweeping up and down.
Message 83 of 92
(1,237 Views)
Those are not LabVIEW functions. If you want to verify whether or not they are valid for your instrument, the first two places to check are in the manual and then Keithley tech support.
Message 84 of 92
(1,235 Views)
ymanglik2009@gmail.com wrote:
Hello everyone,
:SOUR:SWE:DIRE UP;
:SOUR:SWE:DIRE DOW;
You have to eventually do some of the legwork yourself, you know.  You have to consult the manual to figure out if the commands are valid or not.  You can't send random commands and expect them to work.
Bill
CLD
(Mid-Level minion.)
Message 85 of 92
(1,224 Views)
Hello everyone,
Can anyone tell me how to sweep down in a program of keithley through command without showing readings????
Or which command should i use to do this.
Reply fast
Regards
ymanglik
Message 86 of 92
(1,197 Views)
Fast reply:
Read the Keithley manual as said here, here, here, here, …
You may even call the Keithley support as suggested here, or here
What have you done so far?
Message 87 of 92
(1,188 Views)
Hello Yamaeda,
You dont, you switch the cables. 🙂
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 88 of 92
(1,176 Views)
Hello everyone,
Can anyone tell me how to save readings in a separate file using VISA in program of keithley 2410 sourcemeter. What I have tried, I am sending you but it is not working or I am not able to understand which file support labview measurement because its require  .lvm extension file.
Message 89 of 92
(1,157 Views)
That codes makes absolutey no sense at all. Why would take string data and do a file read?
Message 90 of 92
(1,150 Views)
